Jcfarm
#1 Posted : Tuesday, October 15, 2013 5:27:03 PM(UTC)
Jcfarm
I had a solid running beer fridge until a couple weeks ago. First it stated getting too cold, then not running at all. I rapped on the temp control and it fired up so I installed an aftermarket temp unit this week. The fridge ran fine for a day, then started freezing everything inside. Tonight I went for a cold one and everything was warm. I gave the temp control another smack and it started up again.
What in the world am I dealing with?
Thanks for any help!
#2 Posted : Wednesday, October 16, 2013 10:57:29 AM(UTC)
You probably have refrigeration problems. Measure the freezer temperature and post.
Jcfarm
#3 Posted : Wednesday, October 16, 2013 5:28:27 PM(UTC)
Jcfarm
Thanks for the reply. I got home today and fridge had shut down again. I tapped on the temp control and it started right up. Both controls are maxed out and it has been running for aout three hours.
Freezer is at -13.2 and fridge is around 28
#4 Posted : Thursday, October 17, 2013 12:51:30 AM(UTC)
If you routed the new control sensing tube exactly where the old one was, you probably have a bad control, or not the right one for your fridg.
It's also possible you have restricted airflow to the fridg section, just check for an ice jam.
