Leslie Meyer
#1 Posted : Wednesday, April 29, 2009 12:00:39 PM(UTC)
Leslie Meyer
power button will not stay engaged before or after test
#2 Posted : Thursday, April 30, 2009 7:02:30 PM(UTC)
If I got it right the problem is the "on-off" switch does not stay in "on" position?
What is the complete model number of the dishwasher?
Leslie Meyer
#3 Posted : Monday, May 4, 2009 5:13:24 AM(UTC)
Leslie Meyer
The Model No. is SHI4302UC/ uc06 if I hold the button it runs.
The on off switch only works if you hold it in; I just rebuilt the pump and cleared the debris from the water inlet solenoid… Why won’t the button hold? Is there some other component that needs to engage before the button stays in?
#4 Posted : Monday, May 4, 2009 8:57:44 PM(UTC)
If the switch does not stay "on" then it has to be replaced.
- The part number for the "on-off" switch is AP2804248
Here are the breakdown diagrams and Replacement parts for BOSCH SHI4302 UC/06 -FD8002 | AppliancePartsPros.com
diagnostics test programs (Washer Repair)
by plumber72 9/7/2011 4:38:48 PM(UTC)
