poodle123
#1 Posted : Wednesday, October 9, 2013 2:43:10 PM(UTC)
poodle123
I have ordered a clutch (34.00) timer (115.00) lid switch (28.00) all with in a 3 week period . Because washer would not advance to rinse . all parts are on washer and now water just runs out won"t even wash , i am broke buying parts . i had to spend (40.00) at laundry mat to get caught with up laundry .all parts were recommened by pros . i am losing faith with you guys . Model # atw 4475 vqo , please help just want my washer or am i doomed with the laundry mat ?
fairbank56
#2 Posted : Wednesday, October 9, 2013 3:07:52 PM(UTC)
fairbank56
Groups: Expert
What is the problem? Washer should fill, agitate, drain, spin, then fill again for rinse cycle, agitate, drain, spin. Is it just filling and then doing nothing? No noise? Does timer advance at this point? What if you advance timer manually to spin? Still nothing? No noise, timer still won't advance on it's own? You've replaced the lid switch? Likely problem if this is what's going on is a bad neutral connection at motor connection or motor thermal overload switch connections.
Eric
