ROPER Dryer is heating, NO engine noise, and NOT spinning. Belt is OK. Please let me know how to fix it! Million Thanks!
So you're saying it heats up and just doesn't spin?
Originally Posted by: HumboldtRepairMan  So you're saying it heats up and just doesn't spin? Yes, it heats up, but no noise and no spin.
The model number you supplied is incomplete or inaccurate.
Originally Posted by: HumboldtRepairMan  The model number you supplied is incomplete or inaccurate. Model is RED4440VQ Please help! Thanks!
Still invalid you need one more digit after Q
Originally Posted by: HumboldtRepairMan  Still invalid you need one more digit after Q Now I found the model number = YREX3615EW1 This should be the correct one. Please help. Thanks.
Here are your parts Parts for Roper YREX3614KW1 Dryer - AppliancePartsPros.comSee the attachment for a wiring diagram It is for a REX3615EW1 but should be a close match if not an exact match to your unit. As you can see you should not have heat when the motor is off. The centrifugal switch (2M/1M) in the heater circuit should close when the motor gets close to operating speed. This prevents the heater from coming on before there is air flow. Unplug the unit and check the thermal fuse ((item 23 in section 03). It should be 0 ohms at room temperature. Also check the heating coil. Disconnect the wires going to it and check it with a meter, should be about 8 to 12 ohm. Then check from each side of the heater to the frame/ground. Both should be infinite ohms. If not the heater is grounded. In this case you will get heat with the motor off also it will heat whenever the timer is on a heat cycle even before the start button is pressed. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  Here are your parts Parts for Roper YREX3614KW1 Dryer - AppliancePartsPros.comSee the attachment for a wiring diagram It is for a REX3615EW1 but should be a close match if not an exact match to your unit. As you can see you should not have heat when the motor is off. The centrifugal switch (2M/1M) in the heater circuit should close when the motor gets close to operating speed. This prevents the heater from coming on before there is air flow. Unplug the unit and check the thermal fuse ((item 23 in section 03). It should be 0 ohms at room temperature. Also check the heating coil. Disconnect the wires going to it and check it with a meter, should be about 8 to 12 ohm. Then check from each side of the heater to the frame/ground. Both should be infinite ohms. If not the heater is grounded. In this case you will get heat with the motor off also it will heat whenever the timer is on a heat cycle even before the start button is pressed. Hey, Thanks very much for your information. Yesterday I replace the fuse of the dryer and it is running like a new machine! I feel so good that it is working now!!!!!!!!!!!!!!!!! tt2601:)
Did you find out why it blew?
Also if the thermal fuse on the blower motor blows, the motor will not start and you should not have had any heat because the heater's centrifugal switch on the motor should never close.
I hate to be a spoil sport but I think you still have a problem. |
