4 Pages<1234>
engeraSidge
#21 Posted : Wednesday, September 11, 2013 9:19:35 PM(UTC)
engeraSidge
Hello
I've recently found astomishing
haarausfall stoppen
engeraSidge
#22 Posted : Wednesday, September 11, 2013 9:21:03 PM(UTC)
engeraSidge
Hi everyone!
I've recently spotted faboulous
haarausfall stoppen
engeraSidge
#23 Posted : Wednesday, September 11, 2013 9:28:54 PM(UTC)
engeraSidge
Good day!
I've recently found wonderful
mittel gegen haarausfall
engeraSidge
#24 Posted : Wednesday, September 11, 2013 9:31:04 PM(UTC)
engeraSidge
Hi!
I've recently come across fantastic
haarausfall m&#228;nner
engeraSidge
#25 Posted : Wednesday, September 11, 2013 9:32:58 PM(UTC)
engeraSidge
Hey
I've recently come across astomishing
haarausfall stoppen
engeraSidge
#26 Posted : Thursday, September 12, 2013 12:36:28 AM(UTC)
engeraSidge
Hey I've recently come across amazing haarausfall bei m&#228;nnern
Joe / APP Team
#27 Posted : Thursday, September 12, 2013 5:22:39 AM(UTC)
Joe / APP Team
Originally Posted by: erf Go to Quoted Post
Well, I've come against a (hopefully minor) block... I got the dishwasher door cover off, but all the electronics are in a black box that, at first glance, seems to be secured pretty tightly to the door itself. There looks like there may be some tabs holding it on to the door, but I didn't have a chance to poke and prod it at all. I'm afraid if I force the tabs, they may break. Does this sound familiar at all?
Thanks!
Erf, Yes, The control board cover
Part number: AP3044292
is secured to the panel assembly with "tabs". You will probably need a flat blade screwdriver to release the tabs and lift the cover up and off the control board and panel assembly. Just don't overdo it, in most cases once you release one or two of the tabs, the cover comes up and off easily.
Utelliptani
#28 Posted : Thursday, September 12, 2013 3:15:52 PM(UTC)
Utelliptani
Hey
Check out. amazing
tabletten gegen Haarausfall
erf
#29 Posted : Wednesday, September 25, 2013 3:33:36 PM(UTC)
erf
Hi again all (especially Joe!)...
OK, got everything taken apart, ordered the wrong thermal fuse, ordered the right one, and now have the most ridiculous problem.
I snipped the wired from the old thermal fuse, stripped the insulation and now have to connect them to the terminal block on the new thermal fuse.
Problem: The wires will not stay connected to the terminal block.
I loosened the screws on the block, put the exposed wire ends into the holes, and tightened the screws until I couldn't tighten them any more. Result? The wires pop right out with just a mild tug (or less).
It's a very simple operation, which I've done before on other devices, but it's like the screws won't tighten enough to grab onto the wires and hold them. I tried stripping the wire with shorter or longer exposed ends, but no difference.
Have you ever heard of anything like this? Any suggestions? The wires from the thermal fuse to the terminal block seem to be very secure. Not sure what I could be doing wrong. The only thing is that the screwdriver I'm using to get to the screws that are that small has a VERY small handle... I'm wondering if that's preventing me from tightening the screw enough? I kind of doubt it, because when the wire pops out, it looks like screw is down pretty far, but maybe not far enough.
Any thoughts? I'm going a little nuts at something so simple causing so much trouble!
Thanks again (again!)
-Eric
Joe / APP Team
#30 Posted : Thursday, September 26, 2013 5:51:05 AM(UTC)
Joe / APP Team
-Eric
Eric, Haven't had that issue myself, but then I had several "custom" tools for "special" occasions. A couple of things to try, Get an inexpensive set of "jewelers" screwdrivers from the local hardware store. If you have a soldering iron and solder, you could solder the end of the wire, so that when the screw tightens the individual wire strands don't separate and you'll get a very tight proper connection.
4 Pages<1234>
