Hey guys I just bought a new house! (whoop whoop) But the LG Freezer that came with it keeps leaking water.. :( The inside of it looks like this: After a very extensive examination, I have tracked the problem to the Ice Maker. It looks like this: The tray is actually loose on the left side, and I can wiggle it around.. I am very mechanically inclined (Do most of my own auto repairs), have worked on washers / dryers / dishwashers, but have NO (read: 0) experience with a refrigerator.. What is wrong with it? Should I call a repair man? Thanks for the advice! File Attachment(s): setheroth attached the following image(s):
Try calling LG to see if they have a recall on it. LG fridges are known for problems especially icemaker issues amongst other things.
LG sucks, Kelvinator Rocks..
Here are your parts Parts for LSC27914ST - AppliancePartsPros.comLooks like something is wrong with the tray mounting. If you look at the section with the ice maker and then click on the parts picture or description a new page will open often with more views of it and info. Perhaps this may help figure out what is broken/installed wrong. Part number: AP4438280
Looks like the stud on the left hand side should be holding it up. Perhaps it is broken off or has jumped out of where it should be. |
THIS FORUM IS DEAD!!!!!!! |
