tommy_boy
#1 Posted : Friday, September 20, 2013 2:53:13 PM(UTC)
tommy_boy
The dishwasher was working fine until 2 days ago. Now, it starts a cycle for a few seconds then stops.
I tried to reset, but no go. Checked for continuity on the hi-temp fuse and there's none. So, i jumpered the 2 wires going to the fuse, and still no go. There's a leak i think is coming from the check valve.
I'm going to replace the check valve, could that be the problem?
Thanks in advance for your help
tommy_boy
#2 Posted : Saturday, September 21, 2013 8:42:20 AM(UTC)
tommy_boy
Come on guys and gals, i've read far more complicated issues resolved on this great forum. Any help would be greatly appreciated. Could it be a control board?
tommy_boy
#3 Posted : Sunday, September 22, 2013 11:38:13 AM(UTC)
tommy_boy
Ok, let's try this one more time.
The dishwasher starts for a few seconds, fills water and then stops. Drained the water from hose and i checked the hi temp fuse without removing it. Don't really know if my continuity test is valid that way or not, but it shows that there was no continuity.
What other test can i do to isolate the problem?. The leak is a 2nd issue. Tried to look with a flashlight at the check valve. There's a leek close to it, but i'm not sure if it's from the check valve or not since i didn't pull the dishwasher out.
Next step for me is to pull the dishwasher out to get a better view.
Thanks in advance.
