kevinsvoboda
#1 Posted : Friday, September 20, 2013 9:15:08 AM(UTC)
kevinsvoboda
I have a unique situation here, maybe its happened before:
i have a "Old School " GE traditional frig from the 70"s that is a great collector for "retro" lovers. Its copper colored and beautiful . The freezer is on top - frig on bottom . 17.6 Cu Ft
the problem is , when its plugged in , the lights work and its fine. BUt when you turn the dial to start it , , it blows a breaker and shorts out. !!
it has been sitting idle for 8 months and is used only 4 months a year. Its a 1970's vintage model so it well made and i dont want to trash it to a land fill.
please advise , or send links where i can get a service manual and to diagnose the problem
#2 Posted : Saturday, September 21, 2013 3:18:21 AM(UTC)
Parts for GE TBF18EAB Refrigerator - AppliancePartsPros.com
I doubt that a service manual is available but with luck someone else will jump in with one.
GE is a pain to get any tech info on.
Could be a number of things.
First I would try it on a different outlet, just to be sure it is not a breaker problem.
Next I would disconnect the condenser/compressor fan then reapply power to eliminate it as a possible cause.
If OK reconnect it.
Disconnect the compressor and give it a try.
This is the most likely cause.
It may be the compressor or the start relay.
If it no longer blows the breaker below is a good site with info on how to check it.
How To Fix a Refrigerator - Appliance Repair Guide - ACME HOW TO.com
If it is not the compressor reconnect it and try disconnecting the evaporator fan in the freezer.
