DW started on Normal Cycle. Runs about 45 mins, then stops with Start/Resume light flashing (like someone opened the door, which did not happen). Water in bottom (not drained), very hot. Press Start button and DW resumes. Runs about 5-10 mins and stops completely, no response or lights on control panel at all. After about 10-20 mins, lights return (Start flashing constantly). Have replaced control module and thermal fuse/breaker to no avail. Help!
