Notice our dishwasher making a funny noise. The lower spray arm is really loose and rubbing and hitting the water conduit. I believe I need to replace the support hub but cannot figure out how to remove it. Could you please tell me how to remove the support hub?
Thanks Jackie
Part number: AP3129618
If you click on the picture a new page will open, often there is a Q&A section about that part. You can do this with any part but not all of them have a Q&A. I find it easiest to go to the Sears parts site and look up the part number and then come back to AppliancePartsPros and look it up. Sears has actual part breakdown diagrams for their units but do not share these with other part distributors. |
THIS FORUM IS DEAD!!!!!!! |
The part that you reference will it work with Kenmore models 665? It isn't the same as what is on there currently so I am concerned with compatibility.:) Originally Posted by: Naturesblend Notice our dishwasher making a funny noise. The lower spray arm is really loose and rubbing and hitting the water conduit. I believe I need to replace the support hub but cannot figure out how to remove it. Could you please tell me how to remove the support hub?
Thanks Jackie
Not sure as I do not know what is on there.
But if you find the part at the sears parts site then use that part number to reference it back at AppliancePartsPros since they have more views then it should be the correct part. |
