Dear Pros, I recently purchased some leveling screws from APP.com thanks! My Frigidaire gas range Gallery Professional Series FGF379WECR has a very dim LED. I've not taken the back panel off to investigate, but do I need to purchase the complete $207 clock/timer board or is there an LED light that I can replace? Thanks Kurt
Hello, I have the same Fridgidaire Gallery Oven, model FGF379WECR. My Led display became very dim and eventually completely went out. Did you ever find a fix for this?
Thank you, Chuck
Sorry Kurt, we somehow missed your post. Kurt and Chuck, The only solution offered by Frigidaire in such situation is to replace the control board (aka a clock/timer). - The clock/timer Part number: 316080102
You are welcome Chuck. Keep us posted.
Originally Posted by: Gene  You are welcome Chuck. Keep us posted.
Gene. Ok, I the replacement control board arrived yesterday. I installed it last night and everything is working perfectly. Thanks again, Chuck
You are welcome Chuck. I'm glad it's up and running.
Help!! I have the same problem but the control board is no longer in stock anywhere in Canada, US, etc!!! Is my only option to buy a new stove so the temperature light is no longer dim or is there a quality, compatible part!?! Please help, tenants are getting frustrated and I'm trying to find a solution other than buying a whole new stove even though everything else works just fine......:confused:
I think you might wanna look into the rotor..that might be of some help.
Depends on the type of display. If it is a fluorescent display then odds are it can be fixed if you have some electronics experience. See below http://forum.appliancepartspros...ml?highlight=dim+displayThere are companies out there that will repair obsolete boards, just Google "appliance timer repair" The problem is that the unit will be down while the board is being fixed. |
THIS FORUM IS DEAD!!!!!!! |
