Hi My oven broil element is always on when we turn the oven bake on, and it s on if we turn only the broil, could any one advise me what should i have to do? Many thx in adavnce
Sounds like your main panel or main bake switch is shorting out causing them both to come on or you have a short somewhere in your harness. Since you didn't supply a model number i can't tell you what part you might need.
Thx for your answer. I don t know which model or number is this Admiral. it s really old one with a logic watch in the middle.
pull out the bottom drawer and look for a tag or behind the unit or it could be under the burners.........without a model number you can't find the parts you need.
