javal
#1 Posted : Tuesday, April 28, 2009 10:53:57 AM(UTC)
javal
My ice maker on the Frigidaire Gallery makes the ice and but it just does not throw them into the ice holder box. Everything works but it just does not throw the ice anymore. I have to manually break them off and dump out myself. I am not too sure what part I need.
#2 Posted : Tuesday, April 28, 2009 1:23:39 PM(UTC)
If the ice maker does not release ice cubes then the problem could be a bad mold heater, a bad motor, a bad thermostat or a broken ejectors. The best solution is to replace the ice maker.
- The part number for the ice maker is AP4299334
Here are the breakdown diagrams and Replacement parts for FRG GLRS267ZDW2 | AppliancePartsPros.com
javal
#3 Posted : Wednesday, April 29, 2009 8:16:23 AM(UTC)
javal
Thanks Gene appreciate your help.
#4 Posted : Wednesday, April 29, 2009 11:40:54 AM(UTC)
tdraym
#5 Posted : Wednesday, April 29, 2009 5:09:30 PM(UTC)
tdraym
Ice maker stopped letting ice fall into box , but now it is just clicking rather then turning the arms to drop it , it says dont rotate by hand sowhat do I do next. this is the 3rd. ice maker I have had in the unit , and why dont they work to good. needsome help before replacing again
#6 Posted : Wednesday, April 29, 2009 6:07:10 PM(UTC)
The ice maker definitely has gone bad and has to be replaced. When did you replace it last time?
tdraym
#7 Posted : Thursday, April 30, 2009 1:57:00 AM(UTC)
tdraym
I replaced the icemaker over 16 mos. ago, but how long are they made to last , this is the 3rd. one in 8 years. thank you
