markwads
#1 Posted : Monday, September 9, 2013 10:46:58 AM(UTC)
markwads
My freezer has not been cold enough to kep stuff frozen. I heard what sounded like the hiss of water dripping on a hot surface. I felt what I think is the evaporator cover; it ranged from warm at the top to hot lower down. Is there something wrong here that could be causing my problem?
#2 Posted : Monday, September 9, 2013 11:08:01 AM(UTC)
I cannot find info on your given model number.
Following is what comes up when I use your number.
http://www.appliancepartspros.c...earch.aspx?model=sxd25sw
See the models in the Matching Model Numbers section.
Please check the model number.
What you felt was the unit doing a defrost cycle.
This turns off the compressor, the condenser/compressor fan and the evaporator/freezer fan. It then turns on the defrost heater which is under the evaporator coils.
Defrost occurs about once every 8 hours of compressor on time. Defrost is usually a fixed time (30 minutes or so) but there is a thermostat clipped to the top of the evaporator coils. It opens just above freezing (frost has melted) and kills power to the heater for the remainder of the defrost cycle.
Perhaps it is not opening and therefore too much heat is being introduced into the freezer.
After defrost your fans and compressor should comeback on and cool down the unit.
From your description it sounds like the compressor does come back on but the unit does not get cold enough.
The freezer should be between 0 and 5 degrees F.
If not.
Is the compressor on. You can usually hear it but should also be able to feel it vibrating.
Is it cycling or on all the time other than when it is in a defrost cycle?
Is the condenser/compressor fan on?
Is the evaporator/freezer fan on?
Is the problem that the food thaws during defrost and then re-freezes?
It should not do this as defrost should not add much heat to the freezer compartment.
markwads
#3 Posted : Monday, September 9, 2013 12:03:52 PM(UTC)
markwads
Model is SXD25S2W. It sounds like the compressor is running. It doesn't run continuously. There is cold air blowing from the vents at the top and middle of the freezer. There is warm air blowing out the back of the cabinet. The panel right now is not hot, but it is definitely not cold. It's cooler than my hand--perhaps in the 50s or so.
You said "From your description it sounds like the compressor does come back on but the unit does not get cold enough." That's right.
Yes, some things thaw; not all refreeze.
#4 Posted : Tuesday, September 10, 2013 5:36:51 AM(UTC)
If the compressor is cycling then it could be that the main control thermostat is bad re: not measuring the temperature correctly.
Check your freezer temperature, should be 0 to 5 degrees F.
If higher and the compressor cycles, try a colder setting.
If that does nothing.
Unplug the unit.
Short the two thermostat wires together.
Make sure they cannot short to anything else.
Plug the unit in.
Compressor should come on and stay on unless the unit goes into defrost.
Chjeck your freezer temperature to see if it is getting colder.
markwads
#5 Posted : Tuesday, September 10, 2013 2:39:40 PM(UTC)
markwads
Last night I took out the thermostat to check it. When it was above freezing, it was open. After being in the deep-freeze for a few minutes, it conducted. So I concluded that it's probably OK and I put it back. The freezer was not cold by this time. I plugged it in and have been recording the temperature since then. It went from about 50 down to the low 30s in about 4 hours, then went up to the mid-40s and has been coming down since; after about 8 hours total it's back down to below freezing. It seemed to be rising the last few minutes, but it's still in the low 30s. The panel was cold when I just felt it.
BTW, the freezer is set to its coldest setting. The compressor has been running whenever I've checked. (The temperature is recorded once a minute electronically without opening the door.)
Too much information?
#6 Posted : Wednesday, September 11, 2013 1:19:09 AM(UTC)
[COLOR="Blue"]Too much information?[/COLOR]
Never can get too much info.
When the compressor runs the unit should cool down that is why knowing if it is on all the time is important. It will eventually hit a point that it cannot cool down anymore but this should be well below 0 degrees F.
Remove the cover in the freezer so you can inspect the evaporator coils.
Try to ensure that the compressor has run for at least an hour because if you do this shortly after or during a defrost cycle you could end up with the wrong diagnosis.
Three things can cause the compressor to run and not cool the unit down to the set point temperature.
1. Enough air is not being pulled through the evaporator coils to cool it properly.
Check that the evaporator fan is OK.
Check that the coils are not heavily iced/frosted over (plugged). If they are this points to a defrost problem.
2. A sealed system problem (low freon etc.).
If the coils have frost in one area (usually where the freon enters them), then it is a sealed system, problem.
This will be an expensive repair as you need a pro.
Often it makes more sense to put the dollars towards a new unit.
I would check the warranty on the unit as sometimes the sealed system has a longer warranty.
Below is a good site, take a look at the 3 example pictures about half way down the page.
http://www.applianceaid.com/ref...ator-not-cold-enough.php
3. This is the long shot as you would probably notice a large cold leak.
Check the door seals. If you have a very bad seal. If there is so much warm air getting into the unit that the compressor can not cool it down.
markwads
#7 Posted : Friday, September 13, 2013 9:42:18 PM(UTC)
markwads
It seems to bottom out at about 25 degrees. It looks like the defrost cycle comes on avery four to six hours, the temperature shoots up to around 40-45 and then sags back down to about 25. The compressor seems to be running pretty much all the time, so it looks like it just isn't producing enough cold air. I looked at the evaporator coils. There was a measurable layer of frost (1/8" to 1/4") on the first coil. less on the next, and pretty much none from the fourth coil on down. So it looks like your option 2 is the right one. The fridge will be 18 years old next week.
Guest (4)
Ref hot Freezer ok (Refrigerator & Freezer Repair)
by Dick Tunender 7/27/2012 10:37:23 AM(UTC)
very hot freezer door (Refrigerator & Freezer Repair)
by CathyC 4/4/2009 12:33:46 PM(UTC)
