chaucee
#1 Posted : 12 years ago
chaucee
Originally saw an F then H signal but now lights are continuously flashing on my Whirlpool Duet wash machine. Also, door doesn't open. Did remove bottom panel and unlatch the door. After replugging and shutting door, lights are still flashing. Clothes are very, very wet and have not drained. Any solutions? Don't know how to see your answers
HumboldtRepairMan
#2 Posted : 12 years ago
HumboldtRepairMan
FH is basically saying there's not enough water coming into the unit or the pressure switch or connections aren't working properly.
Press PAUSE/CANCEL twice to clear the display.
Potential Causes
• If there is no water in the unit:
• Make sure that both valves at the water source(s) are turned on all the way.
• Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
• Verify inlet valve operation
• If there is water in the unit:
• Verify Drain pump operation
• Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
• Verify there is not a siphon problem
• Verify wire harness connections to; Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
• Check all hoses for possible leaks
• Verify pressure switch operation
• Verify flow meter operation
• Verify CCU operation
