delta co
#1 Posted : Thursday, September 12, 2013 7:46:21 AM(UTC)
delta co
The dryer cabinet and clothes were extremely hot. I followed the advice of several online sources and tested several parts of the dryer. Exhaust tube is spotless, blower works, tested the heating element with ohm meter (removed wire and it tested at 10.2 ohm) I turned the dry to air only mode and the element still came on. Tech sheet in dryer said to test the P4 connector at the 3 and 6 wire. I didnt get any reading at all at the plastic connector (or was I supposed to test those positions onthe circuit board?) So is it the control board that is bad?
#2 Posted : Monday, September 16, 2013 3:19:04 AM(UTC)
http://www.appliancepartspros.c...ch.aspx?model=wed9500tw2
When you checked the heating element did you also check to see if it was grounded?
Unplug the unit.
Measure from each side of the element to the machines frame/ground.
Both should be infinite ohms.
If the element is OK then odds are that the control board is toast, perhaps the heater relay contacts are welded together.
delta co
#3 Posted : Tuesday, September 17, 2013 7:37:11 AM(UTC)
delta co
where are the heater relay contacts?
#4 Posted : Tuesday, September 17, 2013 7:40:07 AM(UTC)
Take a look at the parts, Bulkhead Parts item 14.
delta co
#5 Posted : Tuesday, September 17, 2013 9:00:05 AM(UTC)
delta co
Bulkhead itme #14 is the heating element. I tested it. The tech sheet said to check the #3 and #6 wires of the P4 connector for continuity, which i did but got no result. Also I could not find the control panel on the parts diagrams you pointed me to.
#6 Posted : Tuesday, September 17, 2013 9:46:12 AM(UTC)
Oops must have had my head up my you know what.
Saw the heater part but the relay part did not register.
The part you want is item 40 in the Cabinet Parts section.
The relay is on the control board not the control panel.
When yu checked the outlet thermistor were you on a high enough meter scale.
At room temperature it should be about 10,000 ohms so your scale must be higher than this.
