huntnfishn5280
#1 Posted : Wednesday, September 11, 2013 1:59:10 PM(UTC)
huntnfishn5280
I have a RF374PXDW1 Whirlpool electric range in perfect condition. Started throwing codes so had a tech look at it. He says is just the thermal fuse (part# 3187848). I can't find one anywhere. Are these things rated for temp or what? Seems like there should be another fuse that could substitute if the heat rating was the same. Any suggestions?
Scott in Denver
HumboldtRepairMan
#2 Posted : Wednesday, September 11, 2013 5:11:57 PM(UTC)
HumboldtRepairMan
Contact Whirlpool directly with your question and to find aftermarket parts that may be good for your problem.
http://www.whirlpool.com/contact-us/
huntnfishn5280
#3 Posted : Wednesday, September 11, 2013 6:23:21 PM(UTC)
huntnfishn5280
Already did, they were no help.
#4 Posted : Thursday, September 12, 2013 6:40:18 AM(UTC)
Parts for Whirlpool RF374PXDW1 Range - AppliancePartsPros.com
See the attachment for the tech sheet
I doubt it is the fuse as it looks like it kills power to the control board.
Have you tried unplugging the unit for a couple minutes to see if it will reset.
File Attachment(s):
RF374.pdf (254kb) downloaded 10 time(s).
huntnfishn5280
#5 Posted : Thursday, September 12, 2013 6:50:58 AM(UTC)
huntnfishn5280
We've tried everything. The fuse reads open. I found a fuse on ******** yesterday. If that doesn't work I'm not going to waste money on a board. It's 16 years old and will be scrap metal at that point.
