I get the ul code, redistribute the load, and immediately get the code again. I emptied the basket and still get the ul code and it resets to 12 minutes and tried again.
Have removed all of the insides and the cleaned the shaft. Put it all together and same problem.
Shaft squeaks and there is brown/rust colored residue in the bottom.
Can the shaft be oiled? Any other ideas?
