BLACKATTACK
#1 Posted : Saturday, September 7, 2013 7:31:11 AM(UTC)
BLACKATTACK
Fridge stop working over night and all the Lights and Fans work but the compressor and compressor fan don't work at all?
#2 Posted : Saturday, September 7, 2013 7:49:01 AM(UTC)
You are missing the last digit in your model number.
Without it I cannot be sure that I can find the correct wiring diagram.
The ones I did look at had the compressor, the condenser/compressor fan and the evaporator/freezer fan all wired in parallel. So when one is on they all should be on.
Since your evaporator fan is running I would say that you have a connector or broken wire problem.
