noelc
#1 Posted : Friday, September 6, 2013 7:36:21 AM(UTC)
noelc
I have a defrost problem on my fridge. I think the machine has a circuit board in stead of an defrost timer. How do you check/cycle the board. I need to do the trouble shooting to see if the board has gone bad. thanks noel
#2 Posted : Friday, September 6, 2013 8:53:24 AM(UTC)
See the attachment for the tech sheet
File Attachment(s):
6934600.pdf (564kb) downloaded 23 time(s).
noelc
#3 Posted : Sunday, September 8, 2013 7:50:23 PM(UTC)
noelc
I have done the test for a bad defrost cuirct board.The defrost haeter is working. Where is the baffle located?? Baffle module? The freezer on the fridge is working but the fresh food side doesn'r quite get cold enough. Is there a opening at the bottom of the fresh food side so the cold air can circulate back into the freezer. I have blown the coils out. thanks again
#4 Posted : Monday, September 9, 2013 2:33:39 AM(UTC)
[COLOR="Blue"]I have done the test for a bad defrost cuirct board.The defrost haeter is working.[/COLOR]
I am assuming that when you did this that the evaporator coils were not clogged solid with ice/frost.
Just because the heater comes on does not mean that defrost is OK.
Sometimes you can force the defrost but the board does not program/schedule a defrost cycle automatically.
[COLOR="Blue"]Where is the baffle located?? Baffle module?[/COLOR]
If you go to the Sears parts site they have actual part breakdowns.
Unfortunately they will not share theses with other parts vendors.
The baffle/diffuser is at the back of the control assembly in the fresh food [COLOR="Blue"]side. It is mechanically linked to the control knob/wheel.
Is there a opening at the bottom of the fresh food side so the cold air can circulate back into the freezer.[/COLOR]
Yes there should be a vent between the two sections lower down on the dividing wall.
noelc
#5 Posted : Monday, September 9, 2013 3:05:46 PM(UTC)
noelc
When I got to the side x side it was already defrosted. When I forced the defrost everything was thawed out.I could feel the heat off the def heater. The freezer was freezing and the fridge was cold but not enough.thanks again
