baddogtitan
#1 Posted : Monday, April 20, 2009 3:48:22 AM(UTC)
baddogtitan
I have an Amana ARB9059CS bottom mount freezer refrigerator. About two weeks ago, it iced right up. I took the back panel off and defrosted everything. The drain to the drain pan was not plugged, and the melt water drained fine.
I tested the defrost timer, the defrost thermostat and the defrost heater and everything passed. The timer was advancing, the thermostat was closing when cold, and the heater showed 32 OHMs. I also burned my finger when I touched it during a defrost cycle!
I figured it must be the timer, so I replaced it, and about a week later everything iced up again. I retested the components, and they all still appear to be working properly.
My only other thought is it could be the thermostat on the threshold of failing? Should I just replace it anyways?
#2 Posted : Monday, April 20, 2009 4:19:10 AM(UTC)
Yes, I would replace the defrost thermostat.
Something has gone intermittent so you are playing the odds.
The odds are that the thermostat is more likely to go intermittent than the heater.
baddogtitan
#3 Posted : Monday, April 20, 2009 4:27:31 AM(UTC)
baddogtitan
Thanks, Denman. I, too, can't see the heater going intermittent. From what I know, they usually just burn out. I also can't see having two bad timers!
I hope the repair shop will take back the new thermostat........
#4 Posted : Monday, April 20, 2009 5:47:17 AM(UTC)
Heater can go intermittent but it is rare.
You may want to leave the new timer in the unit especially if the unit is 10 years plus, over time the contacts get pitted and fail.
In most cases supply houses will not take an electrical device back once it has been installed so if you are going to try to return it, call them first rather than waste your time pulling it out.
baddogtitan
#5 Posted : Tuesday, April 28, 2009 3:30:28 AM(UTC)
baddogtitan
You were right. They would not take back the timer. I replaced the thermostat, and the fridge has been working good as new! Even though I have an extra timer, it was still a much cheaper repair than calling in a technician!
#6 Posted : Tuesday, April 28, 2009 4:14:20 AM(UTC)
Yes, much cheaper because they probably would have replaced the timer the same as you did and then hit you up with a second charge when they came out and replaced the thermostat.
Glad it worked out.
