The burners are randomly not sparking. Each burner at times has failed to spark, they light fine using a lighter and the oven works properly at this time. Research that I've done has pointed to the Direct Spark Ignition Control Module, I have had difficulty in identifying where to find the module. The common answer complete with videos shows it to be located in the back in the raised panel. Unfortunately my model does not have the raised panel. A diagram I've found seems to indicate that it is in the front behind the left front burner control. There does not appear to be enough space there for the module as it has been described. Before I start pulling the stove a apart I'd like to get confirmation from someone who has been down this path. Your advice would be appreciated.
