I received a small refrigerator from my parents and when I plug it in it does not work. I checked the outlets and the dial inside the refrigerator. I checked behind the refrigerator as well.
Could it be the start relay? When I plug it in there is no noise at all.
THIS FORUM IS DEAD!!!!!!! |
I tried a relay and that was not the problem. So how do I test the thermostat? I am not sure which wires I need to connect to test? Are the wires I need to connect the wires in the temp. control housing?
Sorry for the delay in getting back to you but I was at the lake.
The thermostat is the device that is controlled by the knob (item 15) in the parts. There should just be two wires going to it. |
No problem....Hope you had a good time at the lake.
There seems to be 3 wires. White, Black and Green. What do I need to do to test it?
Unplug the unit. Short together the white and black.
The green is probably just a ground wire (attached to the thermostat case). Check this as I cannot get a wiring diagram and therefore cannot confirm this.
Then plug the unit in to see if it starts. |
That was it. Now I just need to find a thermostat. That #15 is just the knob.
Yes 15 is just the knob.
Give the parts peple a call as they have access to more info than what comes up on the site. |
