Dremert
#1 Posted : Monday, April 27, 2009 2:49:45 PM(UTC)
Dremert
A few months ago, I had a problem where frost would show up on the back of my freezer and then my fridgerator would get too warm and all of my food would ruin. I figured out that I could unplug the refrigerator and let it defrost, vacuum up all of the water that came out of the bottom of the fridge and plug it back up and use it again for a week or so but this time around, I unplugged it, vacuumed up the water and when I plugged it back up.... nothing except the lights on the inside of the refrigerator. I called someone and they said they thought it might be the run capacitor so I replaced it and it didn't help. Does anybody have any suggestions? I am so broke that I can't afford to hire someone to come out and I can't afford to buy a new fridge so I will take any help I can get. I am thinking that maybe the fan went bad that connects to the Condenser but I'm not sure.
woodchuckie
#2 Posted : Monday, April 27, 2009 8:42:56 PM(UTC)
woodchuckie
Check to see if the condenser fan at the back underneath the fridge is running.
Is the compressor motor near that fan running.
Are the coils warm ,cold or hot.
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. stopped up? clear? ice in one spot . frost everywhere.
Dremert
#3 Posted : Tuesday, April 28, 2009 2:17:36 AM(UTC)
Dremert
The motor and fan are both not running. I don't see any frost anywhere because it has been unplugged for a couple of days. I am going today to try and replace the motor that connects to that fan so hopefully that will fix part of the problem.
woodchuckie
#4 Posted : Tuesday, April 28, 2009 3:55:53 AM(UTC)
woodchuckie
If the compressor motor isn't running check the starter/overload relay. Part 735 in this diagram of your sealed system. http://www.appliancepartspros.com/sect/p/q/b/pqbwjt5zlm.gif
Dremert
#5 Posted : Wednesday, May 6, 2009 6:50:07 PM(UTC)
Dremert
I replaced the overload and the PTCR switch and still nothing. The lights come on but nothing else is coming on. Any suggestions?
woodchuckie
#6 Posted : Wednesday, May 6, 2009 7:32:47 PM(UTC)
woodchuckie
Check the compressor here. Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
Then maybe remove your main board and inspect for burnt or corroded connections. part 801 http://www.appliancepartspros.com/sect/p/q/b/pqbwjt5zlm.gif
Dremert
#7 Posted : Sunday, May 17, 2009 8:26:41 PM(UTC)
Dremert
Ok so I decided to plug up my fridge after about 3 weeks of it sitting unplugged and guess what?? It started working!!! I have removed the back panel of the freezer and I see that almost immediately frost covers the coils from the bottom all the up to the top with the most frost being at the bottom. I see the heater and I did see it work one time today. It melted the ice right off but now, it's not coming back on to do it again.... I hear the fan blowing and it is plenty cold in the freezer and the fridge section but I am not sure what to do now to keep it from freezing up. I can turn the thermostat to zero and the fan stops blowing so that appears to be working. Any suggestions on what I can do next to try and fix this frosty problem?
woodchuckie
#8 Posted : Monday, May 18, 2009 4:02:15 AM(UTC)
woodchuckie
With your motherboard controlling the defrost cycle it comes on whenever it detects it needs to. If it hasn't come on again in a couple of days you may have to replace the mother board. Part 801 on diagram 8. Replacement parts for GE GSS22SGPCSS | AppliancePartsPros.com
Dremert
#9 Posted : Monday, May 18, 2009 2:00:54 PM(UTC)
Dremert
Ok so now it is kicking off and on but the heater isn't lighting up anymore. I actually only saw it do it one time. The color of the heater is black but not all the way black. Is that normal? Also, would a bad heater be the problem if the fridge is turning itself on and off?
