cpatel44
#1 Posted : Tuesday, September 3, 2013 8:23:49 AM(UTC)
cpatel44
this is wall unit combination of microwave on top and oven on bottom
oven not heating
HumboldtRepairMan
#2 Posted : Tuesday, September 3, 2013 5:35:24 PM(UTC)
HumboldtRepairMan
Here's your parts
Parts for JKP86BOF2BB - AppliancePartsPros.com
Here's some video's to help you figure it out
Electric wall oven won't heat - YouTube
#3 Posted : Wednesday, September 4, 2013 4:53:58 AM(UTC)
Could be you have lost half the line voltage.
The control panel, lights and microwave run off of 120 volts but the oven elements require the full 240 volts.
Try the following.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
