Help! When the washer is in spin cycle only, there is loud almost deafing noise during this time. The wash cycle and other functions are normal. Could it be hub or tub bearing. I removed the belt and spun both the water pump and motor shafts. They were smooth ..not gritty.. need to order the right part. Long distance to mom's house for repair.
Hello is Mr. Humboldt there?
Originally Posted by: NOVA621 Hello is Mr. Humboldt there? what part or parts do mi need to order on the tub diagram?
