I have two problems with my GE dryer (model DBVH512EF1WW). The first is the very loud squeeking that takes place anytime I turn on the dryer. I believe it has something to do with the Rear Drum but I don't know what part exactly I need for my dryer.
The other problem I am having is that none of the Sensor settings work on my dryer anymore.:mad: They haven't for a while but my husband didn't seem concerned because the timed part works fine. Since the timed dry works I can still dry clothes but I would love to have my other options back if I can figure out what part I need.
Thanks for any help!
ValB
You should have two moisture bars either near the lint trap or inside the unit running parallel with each other clean them off with windex or take a piece of sandpaper to it they have gunk possibly on them. Best way to test if your moisture sensor setting are is to turn on your dryer with no clothes in it on the moisture sensor cycle, it should shut off in less then 15 minutes unless it's the old fashioned dial type. Here's a video on the GE Dryer noise you may have and want to consider replacing with the rear bearing kit. squeaky dryer - YouTube Rear bearings are infamous for that irritating squeel that will have your neighbors knocking at your door to shut it off. Here's your parts also inspect the front on the panel like the glides on also for wear and consideration to replace also as a pair. Good luck Drum parts for GE DBVH512EF1WW - AppliancePartsPros.com Front Panel parts for GE DBVH512EF1WW - AppliancePartsPros.com
Hey, thanks for your help. I am ordering the parts and I hope to be able to fix it now that I know the parts.
Val
Thanks for the help! Was able to fix the dryer. It is whisper quiet now. And the sensor settings seem to be working. I am very happy. :)
ValB
