yad
#1 Posted : Friday, August 30, 2013 8:26:02 AM(UTC)
yad
I was investigating the cause for a "oL" error.
I removed the basket from a Whirlpool Cabrio (wtw6340ww0) and heard sloshing in the top and bottom floats. I turned the basket upside down and all around to try to see it the liquid would com out but found no leaks,
Is that normal? should there be liquid in the floats?
Thanks for the help
Yad
HumboldtRepairMan
#2 Posted : Friday, August 30, 2013 3:19:18 PM(UTC)
HumboldtRepairMan
Yep it's normal that helps keep the machine level while working.
yad
#3 Posted : Saturday, August 31, 2013 5:53:39 AM(UTC)
yad
Thanks!
I appreciate the sanity check.
Cheers,
yad
