I have a Kenmore Dbl wall oven; the top oven control 'beeps' continually throughout the bake cycle. All of the functions seem to work correctly and the temp sensor has been replaced with no change. The lower oven operates properly.
Sounds like a main board issue if you don't have a F code popping up. Try replacing main board.
Originally Posted by: HumboldtRepairMan  Sounds like a main board issue if you don't have a F code popping up. Try replacing main board. I replaced the main board and the temp sensor, to no avail.
