mikebews
#1 Posted : Thursday, August 29, 2013 9:03:25 AM(UTC)
mikebews
This stove is from the Heritage series. Got it hooked up and the burner knobs wont turn. Its a used stove but it worked for the former owner. Also when oven knob is turned the pilots for the burners ignite momentarily then go out and the oven comes on. Is there a circuit that may be tripped causing the burner knobs not to turn?
HumboldtRepairMan
#2 Posted : Thursday, August 29, 2013 5:55:00 PM(UTC)
HumboldtRepairMan
You gave no model number and if you can't turn the burner knobs then they are all broken and need replacement. And you say it has a pilot light and a spark? That's not normal in most models
