hecven101
#1 Posted : Thursday, August 29, 2013 6:21:19 AM(UTC)
hecven101
Help. My GE Nautilus won't drain at all (not even partially) and after all the troubleshooting I still can't get it to drain. Here are the steps that I have already done:
I first removed the sump filter inside the machine and did not notice any material that caused any obstructions. I then checked for a blocked drain pipe by unscrewing it at the drain point under the sink and found nothing there. Next I removed the kick plate and checked that the Selenoid underneath would pull down when the machine would go into the drain phase. I even removed the drain pipe at the machine to make sure there was not a plug at that end with which there was not. I also checked the Piston and Nut which is located at the rear of the unit and has to be unscrewed. That was also ok.
I can't think of anything else. Am I missing something? Any help is appreciated.
HumboldtRepairMan
#2 Posted : Thursday, August 29, 2013 5:56:28 PM(UTC)
HumboldtRepairMan
Did you check voltage at the drain pump after hitting cancel/drain?
hecven101
#3 Posted : Friday, August 30, 2013 3:40:41 AM(UTC)
hecven101
Hey Humboldt I ordered a new drain Selenoid so I hope that clears it up before checking the voltage on the old one. Thanks for the reply.
HumboldtRepairMan
#4 Posted : Friday, August 30, 2013 12:53:48 PM(UTC)
HumboldtRepairMan
should of measured the voltage before you ordered the new drain pump but we'll see i guess
hecven101
#5 Posted : Friday, August 30, 2013 1:16:08 PM(UTC)
hecven101
Hey Humboldt what would be a good voltage read on the Selenoid if its running in good? Only reason I ask is if I run into this problem again I'd like to know if the Selenoid is running good and then I can focus on some other problem. Again thanks for the replies.
HumboldtRepairMan
#6 Posted : Friday, August 30, 2013 3:08:53 PM(UTC)
HumboldtRepairMan
No............sounds like you don't have much of a background in electrical testing.........good luck with the new pump
HumboldtRepairMan
#7 Posted : Friday, August 30, 2013 3:08:56 PM(UTC)
HumboldtRepairMan
