discoveryone
#1 Posted : Tuesday, August 27, 2013 12:05:35 AM(UTC)
discoveryone
I THINK ITS 2006 model, the washer binds and does not rotate to do a wash cycle, although it will spin and drain. i replaced the clutch pulley assembly 14 months ago and it worked well till now. i replaced the clutch assembly again a month ago and it functioned yet the machine has gotten increasingly load while running and sounded like a bad bearing sound, then alst week it stopped working again, so i replaced the clutch assembly again tonight and no luck, could it be that there is another bearing in the bowl assembly that has seized up and will not rotate the certain way. Angie in parts said that the bowl assembly is replaceable with the bearing as one unit but 447 $. is there anything else that could be an issue. if i try to run the machine without the belt on, the motor does rotate by itself both ways so i do not think it is the motor in anyway.
thanks,
erik
