GLS0628
#1 Posted : Sunday, August 25, 2013 10:26:46 AM(UTC)
GLS0628
I have model GU980SCG2 and just replaced the motor/pump (#W10428168). I hooked everything back up but it will not run more than about 5 secs without shutting off. I hit the quick wash button and it fills with water. Then it turns water off and the the motor starts and runs for about 5 secs and then clicks off. The washing light remains lite. Then it goes about 3 minutes and trys again. Same thing happens. The timing is exact every time. I timed it during 2 cycles of doing this. The motor ran for 4.7 secs and 4.8 secs. The time between running was 3:09 and 3:10 secs. It is like something is telling the motor to stop. Also when I try to drain the machine the drain/cancel light comes on and the motor makes a humming noise like it wants to start but can't. Then shortly after it makes a click and goes quite. The drain/cancel light remains lite.
It seams like the motor want starts to run so I don't see it being the new motor. Any suggestions for me to look at or test?
thanks,
Greg
HumboldtRepairMan
#2 Posted : Sunday, August 25, 2013 12:56:15 PM(UTC)
HumboldtRepairMan
Hook up your voltmeter to the motors your testing and if you see it drop from 120v to nothing then it's a problem with your harness and or wire connections or the main board..........also check your motors (pump and sump) for continuity, you may have gotten a bad part perhaps.
GLS0628
#3 Posted : Sunday, August 25, 2013 2:59:13 PM(UTC)
GLS0628
Can you give me a little details on your 2 suggestions?
Greg
Guest (4)
