Yesterday morning dryer worked great like usual. Went to use it shortly after and it wouldn't turn on. Read a little online and replaced the thermal fuse, buttoned it back up and it still won't turn on. I should mention that recently it would not shut off with the door open, only when the timer was set to OFF. Anything else I could check? Thanks in advance everybody.
Sounds like your having an issue with your door switch check it for continuity......if a door switch doesn't stop while opening or now your unit won't power up the door switch will not allow it to start if it's not functioning properly.
