2 Pages12>
dummyload
#1 Posted : Tuesday, August 20, 2013 1:00:04 PM(UTC)
dummyload
first symptom relay buzzing on compressor, fix , replaced with booster unit, second symptom , now compressor and fan runs all the time. temp inbox goes to 27dig after 24 hr. defrost timer works correctly, called frigidaire got part#5304404821 cold control ordered of amazon, replaced it, same symptoms. temp in sensor probe tube 17# in box , goes to 27 after 24hr run time. any ideas?
#2 Posted: : Wednesday, August 21, 2013 1:29:33 AM(UTC)
What is the part # you used for the compressor start device
dummyload
#3 Posted : Wednesday, August 21, 2013 8:32:59 AM(UTC)
dummyload
the co. supco #rco810 is all i can read. 3in 1 boost
dummyload
#4 Posted : Wednesday, August 21, 2013 8:45:55 AM(UTC)
dummyload
supco co. #rco810 3in1 boost no buzzing now and frig at 32dig. wont shut off by temp.
#5 Posted : Thursday, August 22, 2013 12:53:05 AM(UTC)
First replace the 3 n 1, as it will eventually burn out your compressor. Replace it with the correct start device for your frid.
dummyload
#6 Posted : Thursday, August 22, 2013 10:12:03 AM(UTC)
dummyload
YEs i intend to do just that,however the unit has been turning it self on by temp control but not off when reaching set temp. is this a one of the two factory adjustments on the temp control it self. maybe the bellows main spring tention adjustment or the toggle spring adj? this is a new temp control? thanks for your time and help. im lost here for a fix.
#7 Posted : Friday, August 23, 2013 12:56:55 AM(UTC)
You might have an inefficient compressor, or refrigerant leak, measure the freezer temperature and post.
dummyload
#8 Posted : Friday, August 23, 2013 7:27:42 PM(UTC)
dummyload
fresh food area lowest 24dig. cold control sensor plastic tube 17dig. i dont rember freezer and i unplugged unit. if low on freon can cold control internal adjustment to bellows sping screw be made for compensation and change limits?
#9 Posted : Saturday, August 24, 2013 1:15:07 AM(UTC)
Freezer temperature measurement is needed to determine status of system.
dummyload
#10 Posted : Friday, August 30, 2013 12:21:59 PM(UTC)
dummyload
freezer 9dig. sorry didnt get back to you sooner. thanks for helping!
2 Pages12>
