Giagie
#1 Posted : Thursday, August 22, 2013 12:21:26 PM(UTC)
Giagie
I have a single thermador wall oven, model number M301es/01 it is showing the e009 and e005 codes. I would like to be able to fix this myself if possible but I can't quite figure out which parts are needed. Is it just the control board ? Or board and latch ?
Interface #00702534
Module control board #00655359
Latch #00751505
Any help is much appreciated !
scott5495
#2 Posted : Thursday, August 22, 2013 2:12:35 PM(UTC)
scott5495
these codes mean that there is a loss of communication between the control board and the interface. check for loose wires between the two. you can also try turning off the breaker for about 10 mins. and see if it will reset. if not replace the control board.
