buddha131
#1 Posted : Thursday, August 22, 2013 1:40:30 PM(UTC)
buddha131
Started dryer got no heat, Then got two used coils and got heat for 20 seconds. Cycled twice, then no heat, will not re light. Got good sensor and ignitor. Need to know what I can do to fix this Please. We changed out cycling and Hi -limit,and no help.
scott5495
#2 Posted : Thursday, August 22, 2013 1:59:19 PM(UTC)
scott5495
you may have already covered this but make sure the ignitor is pulling at least 3 amps. any less and the coils will not open or hold open. the ignitor can still glow and be bad.
buddha131
#3 Posted : Thursday, August 22, 2013 2:03:14 PM(UTC)
buddha131
No knowledge on how to do this test with ohm meter?
scott5495
#4 Posted : Thursday, August 22, 2013 2:47:48 PM(UTC)
scott5495
sorry, the amps cannot be checked with an ohm meter. you will need a clamp on amp meter. if you know an electrician he will have one. if not, the ignitor may be cheaper than the meter. amp meters can be purchased at sears. check price
buddha131
#5 Posted : Thursday, September 26, 2013 12:30:17 PM(UTC)
buddha131
Two New coils works better than used ones. Now It works Great. Thanks Scott and to all the A.P.P. team For all you folks do!!!
