dlemenager
#1 Posted : Tuesday, August 20, 2013 2:14:59 PM(UTC)
dlemenager
The dryer has power but when you hit start you can hear a click in the top portion and the dryer does not start. I had a repair guy come to the house and he stated it was the mother board. He wanted $380 to fix it. I gave him $60 for the repair call and ordered a mother board for $100. I installed it myself. That was not the issue. The dryer did the same thing. So we got out the repair manual and have since replaced the door switch and the switch plug. Nothing. It has power and makes a click noise in the upper panel but never starts.
#2 Posted : Wednesday, August 21, 2013 3:56:45 AM(UTC)
Parts for Maytag MEDB200VQ0 Dryer - AppliancePartsPros.com
See the attachment for the tech sheet. I included it just to be sure that we are both looking at the same thing.
I am assuming that all you get is a click re: you do not also hear a hum.
Attach a meter lead to the Neutral at the power cord and leave it there.
Set your meter on the most sensitive resistance scale and short the leads together to see if there is any zero offset in the meter.
White on the door switch should be 0 ohms.
Blue on the door switch should be 0 ohms with the door closed.
Keep the door closed.
P8-4 (Door) on the control board should be 0 ohms.
5M (white) on the motor should be 0 ohms.
4M on the motor should be around 1 ohm.
With the belt switch closed both sides of it should be around 1 ohm.
Both sides of the thermal fuse should be around 1 ohm.
P9-1 (Motor) on the control board should be around 1 ohm.
If all OK then your motor circuit checks out as OK.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
MEDB200.pdf (799kb) downloaded 8 time(s).
