tfd703
#1 Posted : Monday, August 19, 2013 7:30:58 PM(UTC)
tfd703
If any an tell me the steps to changing the drum bearing or if there is a video out there it would be greatly appreciated. Thanks
HumboldtRepairMan
#2 Posted : Monday, August 19, 2013 8:07:22 PM(UTC)
HumboldtRepairMan
The outer (rear) tub should come with the bearing installed check to make sure it is when you buy it....Also replace the gasket in between the tubs.
Here's a helpful video if your bearing isn't installed..also here's schematics on your breakdown pieces...........
ApplianceJunk.com - LG Washer Outer Tub With No Bearings; Installing Bearings - YouTube
LG Washer Disassembly - YouTube
http://www.a
http://www.appliancepartspros.c...hirlpool-wtw6200sw3.html
tfd703
#3 Posted : Tuesday, August 20, 2013 4:11:04 AM(UTC)
tfd703
Thanks hopefully the video will help
