windrider354
#1 Posted : Sunday, August 18, 2013 8:34:55 AM(UTC)
windrider354
My Jenn-air oven suddenly stopped heating. No error codes. Display shows preheat and 100 degrees. Same problem whether Bake, Convect Bake or Broil.
Neither top or bottom element gets hot, but I can hear periodic clicking like a switch is trying to call for heat.
Appreciate advice, especially if it sounds like a single part I can replace.
Thanks very much.
#2 Posted : Sunday, August 18, 2013 8:53:21 AM(UTC)
I cannot find any tech info on this unit.
Parts for W27400 - AppliancePartsPros.com
But the first thing I would check is the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
The heating elements require the full 240 volts.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If the power is good and since the unit stays in pre-heat then odds are high that the control board/timer is toast.
I would check the wiring just in case you have a burned off connector or some other wiring problem.
I cannot find a fuse or thermal cut-off in the parts that would stop power to the elements.
windrider354
#3 Posted : Sunday, August 18, 2013 11:06:00 AM(UTC)
windrider354
Power to oven is OK. Now when I first try to heat oven after power up, I get a F5 code. Only the first time.
#4 Posted : Sunday, August 18, 2013 12:30:54 PM(UTC)
Here is what comers up for that error code.
I cannot confirm that it applies to your unit as I cannot find a tech sheet on it.
F5---Hardware and watchdog circuits disagree---Replace clock assembly (also called the ERC)
