Roddog
#1 Posted : Sunday, August 18, 2013 9:10:16 AM(UTC)
Roddog
I had a small fire in my GE Spacemaker (model # above) and now the control panel is black. Its still getting power whereas the light comes on when I open the door.
I've seen other post regarding this issue but not for my specific model. Any help regarding my model would be appreciated. thanks
scott5495
#2 Posted : Sunday, August 18, 2013 10:24:04 AM(UTC)
scott5495
if the fire did no damage to the inside of the microwave and the fire was caused by overheating food such as popcorn, the micro is repairable. there is a flame sensor, or overheat fuse that has opened. this is a one time fuse and is not resettable. you must take the cover off the micro to access. can be checked with an ohm meter for continuity.
Orenlor
#3 Posted : Friday, August 30, 2013 1:15:41 AM(UTC)
Orenlor
Many times it happens that fire is caused because of overheating of the food. In this situation we have to repair the microwave and change the flame sensor.
http://www.selogerneuf.com/immobilier/ile-de-france.htm
microwave fire (Microwave Repair)
by vbrown 5/26/2009 9:36:53 AM(UTC)
