Solrac45
#1 Posted : Friday, August 16, 2013 7:43:41 PM(UTC)
Solrac45
Dryer trips house breaker when you plug it in. Swapped breakers. Same thing. In my troubleshooting found wheel on idler assembly shot. Wheel was grinding on idler peg. Belt wore away alot of plastic wheel. Could my motor have worn out? Hope this makes sense.
#2 Posted : Sunday, August 18, 2013 2:56:53 AM(UTC)
Here are your parts, includes a wiring diagram
Parts for Maytag PDGT910AWW Dryer - AppliancePartsPros.com
[COLOR="Blue"]Could my motor have worn out?[/COLOR]
it is a possibility.
I would do more troubleshooting.
Does it trip the breaker with the door open?
Does it trip the breaker with the time at off?
If you disconnect the thermal fuse does it trip the breaker?
dryer tripping breaker, not completing cycle & drum not stopping with door open (Dryer Repair)
by hound 9/23/2015 7:57:11 AM(UTC)
kitchen aide electric dryer tripping breaker (Dryer Repair)
by mitsujoe 2/25/2010 3:08:02 PM(UTC)
