DESwish
#1 Posted : Thursday, August 15, 2013 7:28:05 AM(UTC)
DESwish
Purchased a new control panel to install in Whirlpool double oven. The original part was marked Revision E, but the new replacement was marked Revision A. Do the revision levels need to match and what problems can be expected if an A level replaces an E level?
DESwish
#2 Posted : Thursday, August 15, 2013 7:34:19 AM(UTC)
DESwish
I recently purchased a new control panel for a Whirlpool double oven. The original part was marked Revision E, but the new replacement unit was marked Revision A. Do the revision levels need to match and what are the expected problems if the A level is used in lieu of an E level parft?
DESwish
#3 Posted : Thursday, August 15, 2013 7:34:53 AM(UTC)
DESwish
This forum blows
Control Panel Revision Levels (Oven Repair (including Ranges and Cooktops))
by DESwish 8/16/2013 7:46:06 AM(UTC)
