Hello! Thanks again for pointing me in the right direction with fixing my dryer (and having the parts sent to me!). I'm hoping I'll have luck this time as well-
A couple of months ago, I saw my fridge leaking from the bottom. I opened the bottom freezer and saw a 'pool' of ice in the indented pan inside. I took out the bottom drawer and tapped it until the ice was loose. No more ice! Well, a couple weeks later, the same thing happened. Everything else seems to run just fine. Any help would be fantatic!
Also, at the top near the back (but still on the very top) is this little door with a tube- the heck izzat?
Bump.
Ice build up again, and is leaking out again /:
