I have a frigidaire side-by -side. When I unplug the refridgerator and then plug it back in the fan and compressor run for about 30 seconds then shut off. Does this sound like a probem with the board or is the fan/compressor the problem. (perhaps drawing to many amps and therefore being shut down??
Seems like a control problem, check things with a meter.
