In my booklet that came with my dishwasher, it gives a list of error codes and what to do to troubleshoot. I'm getting an error codes C1-slow draining and sometimes C-5. Where:confused: do you access the drain pump to clean it? Is there a screen that could be clogged?
That is bit complicated but push all is and things to be easy you should go your nearest mechanic.
