crankharder
#1 Posted : Sunday, April 26, 2009 1:35:59 PM(UTC)
crankharder
I read on this forum about these Even Heat dryers blowing their circuit board and causing overheating problems. So I went to take apart my dryer to see if this was the cause but I ran into two snags. The first is that the wire seen here:
http://************************...w.php?pic=6h7p0g&s=5
http://************************....php?pic=1zg8gh1&s=5
was just sitting there disconnected. It's Yellow with a red stripe and says "105 C" on it. Does that have anything to do with the thermostat? I could not find where this could possibly have been connected so I haven't been able to plug it back in to see if this solves my problem. Where does it plug in to?
The second problem I ran into is that I cannot get the blower wheel housing out in order to get a better look at the circuitry stuff which is behind it. How do I remove the blower wheel thing?
Thanks!
crankharder
#2 Posted : Sunday, April 26, 2009 1:52:23 PM(UTC)
crankharder
Those links to the pictures should be: tinypic dot com
#3 Posted : Monday, April 27, 2009 1:22:21 AM(UTC)
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%203979705.pdf
Here is a parts breakdown
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.63932101&pop=flush
Looks like Y/R should go to the moisture sensor, Item 34 in the BULKHEAD section. Looks like two metal strips the wire should go to one of them.
Here is a good link
http://www.applianceaid.com/whirlpool-dryers.html
Especially see #40
