I need a little help. I'm trying to remove the defrost drain pan (PART NUMBER: W10189185) from a Kenmore bottom-mount refrigerator (Model #59665932404). The defrost drain pan will not budge because it appears that the fan shroud is locked into the defrost drain pan. There is no room to move the fan shroud up or down to release the defrost drain pan. Now, I'm not entirely sure if I'm able to remove the fan shroud that I will be able to remove the defrost drain pan. There may be more diabolical fastening methods that are cleverly hidden. Joe
