john20091
#1 Posted : Sunday, April 26, 2009 9:03:57 AM(UTC)
john20091
Yesterday we noticed the freezer wasn't cold. Ice cream mushy...etc. So I opened up the back to clean the coils, and noticed the compressor was very hot. I can't keep my hand on it more than 10 seconds, but figured, that is OK b/c is has probably been running all day. I also did some reading, and unplugged the device and got into the coils of the freezer, and there was some frost on them. I pulled out the hairdryer and rid the unit of that.....but even so...after being off for 2 hours, the compressor was still very hot. I didn't want to run it overnight..so I unplugged. This AM, the compressor was back to room temp. I plugged the unit in, and right now, everything is fine (freezer making ice, fridg is 37 degrees.)...however that compressor is still very hot...and even though the inside of the unit is down to the temp level I set...it seems the compressor is running constantly...and as I stated, it is very hot.
So, I'm not sure what is going on. First question is how hot should the compressor be in a normally operating system, or a system that is coming up to normal operating tempuratures (remember, I did unplug it overnight). Not sure if it should be so hot normally (it has now been on 8 hours)...not sure if yesterday was just a result of the kids leaving the door ajar....what should I be observing over the next few hours or days? now to eliminate any items?
woodchuckie
#2 Posted : Sunday, April 26, 2009 10:48:19 AM(UTC)
woodchuckie
Make sure the fan at the compressor is running when the compressor is running.
john20091
#3 Posted : Sunday, April 26, 2009 12:11:27 PM(UTC)
john20091
Today I had the unit away from the wall in the middle of the room and had a fan blowing on it (just to make sure that it wasn't potentially a slow running compressor fan - b/c I had read a story about someone who had the same problem, that had a working fan...but apparently it wasn't blowing hard enough...and when he replaced it.....presto..everything worked great).
Right now, I have placed the back "grill/shield" on the unit...it is still running hot. Tempuratures inside are fine. Working great. What external tempurature should one of these be at when operating normally?
Thank you for the quick reponse...any other ideas will be appreciated.
john20091
#4 Posted : Sunday, April 26, 2009 12:12:31 PM(UTC)
john20091
Oh, just to clarify, the compressor is running hot...not the fridge.
