Our dryer does not blow hot air. Already replaced the igniter, thinking that was it. What would be my next step?
Buy a METER so that you can check the circuts and find your problem!!!! Check the small white thermal fuse at the rear of the dryer.
DO NOT replace the timer until you have checked, Thermal fuse, cycling thermostat,High Limit thermostat and Motor switch!!!! I have NEVER changed a timer on one of these dryers. (I've done this for 26yrs.):)
